| You can also take the temp sensor out of water pipe (bigger one of the two) and "twist-sand" the sensor that touches the coolant with a high grit sandpaper or scrub pad etc. Clean your MAF sensor with some cleaner (do not touch the sensor, just use the spray to clean it and make sure it is completely dry before starting) Also, clean the electrical connection. Also, your 02 sensors may be fouled.. which you can test to see if they are working properly by using the FSM directions.
_________________________________________________________________________ ~~~ Sig starts below ~~~ =================================================================NO, This picture is not photoshopped.
AIM:Shawn300zxTT "-Any closeups on the nuts? - zboost(tx) 19:17:53 08/08/05 -Not really something you want to ask another man about... (n/m) - LordZ 19:24:00 08/08/05" "I just took 45 min and scrubbed the heck out of my rear" teambushido(San Diego, CA) 19:24:51 12/11/04 -1991 Stage _ TT 5spd (Upgraded to hell and back) -1990 Super White 2+2 Na Stage 3 Auto (Deceased :( ) -1990 Cherry Red Pearl ,Auto Coupe (Parts car) -1990 11 Sec Eagle Talon Tsi AWD, (SOLD!) -2001 Ford F-150 Crew cab, 5.4 Triton v8.. Tow bitch -1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car! -2004 Honda CBR 600RR (Candy blue, FOR SALE) |
